Hello, I'm working on an infrastructure project where there is an Infraworks model for the design phase. I need to take that model into a software called Plexos so I can make all the project control from there. That software only works with IFC files that you link into it. I've searched how you can export an Infraworks model in an IFC format but I can't find anything, I would love to know how or to know if it can be done.
Thanks so much.
Solved by andrewofabley. Go to Solution.
Solved by DarrenP. Go to Solution.
these are the only formats you can export to in infraworks: https://knowledge.autodesk.com/support/infraworks/learn-explore/caas/CloudHelp/cloudhelp/ENU/InfraWo...
you can only import ifc files
DarrenP
@Anonymous
Infraworks cannot export these natively, however if you have some ETL tools at your disposal - you can query the underlying sqlite databases and assemble an IFC of some of the data.
It's not straightforward but I have done it in a pinch.
Maybe this one should go to the Ideas forum......I believe this functionality would be appreciated by many.
Thanks so much, frankly I don't know what an ETL is but I appreciate the help. I agree with you, this is something that would be nice to have in Infraworks.
