Error Importing IMX into Civil 3D
VincentSheehan
VincentSheehan
Hi All,
I created a surface in Infraworks 2025 using a *.IMG raster file. It looks good in IW. I then export the surface as an IMX file to import into Civil 3D. I get an error when it tries to import into C3D. I have Civil 3D 2023, 2024 and 2025 install and I get the same error on all three. I also went back to Infraworks 2024 and still get the error. I have the same coordinate set in IW and C3D. The error is below. Thoughts?
IMPORTAIWMODEL
IMX_VERSION: 2.30
_AeccEditDrawingSettings Import started for: C:\Temp\IM_Export.imx.
Importing using this configuration file: C:\ProgramData\Autodesk\C3D 2023\enu\Data\InfraWorks Object Settings\Imperial\All Objects.xml
Failed to import the IMX file. Unknown exception.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Replies (13)
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @VincentSheehan ,
just a shot into dark: Can you test importing the IMX file after opening Civil 3D in a metric profile?
Karsten.
Karsten Saenger
VincentSheehan
That did not work. The export to IMX was working with IW 2025 and C3D 2025. I'm still playing with the coordinate system.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
VincentSheehan
I found this. I'm looking into versions of both C3D and IW.
https://forums.autodesk.com/t5/infraworks-forum/civil3d-failed-to-import-my-imx-file/m-p/9823790#M22...
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
VincentSheehan
No luck. I even tried it on another workstation with the same issue. It must be an update on either software. My Civil 3D version is 2025.1 and my Infraworks version is 25.0.1.66.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @VincentSheehan,
I think it has to do with the underlying raster DEM.
Is it possible to share the .IMG file to recreate the workflow and issue?
You could create a support case in your Autodesk Account to exchange data. Let me know the case number and I will pick it up.
Karsten.
Karsten Saenger
VincentSheehan
I had to Zip the file. I also included the IMG DEM file.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Karsten.Saenger
Autodesk Support
Autodesk Support
thanks for the IMX and DEM files. I could load the IMX fine in Civil 3D 2024 and InfraWorks.
Therefore, I believe something is wrong with the IMX installation on your computer.
Can you test Civil 3D and IMX_EXPORT a DWG (sample file) and IMX_IMPORT it into a new DWG? Does it work?
Can you try to import the same IMX file into InfraWorks?
If you see any error I suggest reinstalling Civil 3D and/or InfraWorks as it could be that the IMX installation is corrupt.
Karsten.
Karsten Saenger
Karsten.Saenger
Autodesk Support
Autodesk Support
And here is a LandXML file of your IMX surface, in case you need it to continue working.
Karsten Saenger
VincentSheehan
Were you able to import it into Civil 3D? I just did another clean install of Infraworks 2025 with no luck. I may do a clean reinstall of Civil 3D 2025.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Karsten.Saenger
Autodesk Support
Autodesk Support
yes, I tested with Civil 3D 2024 and 2025. Both versions import the IMX file just fine.
Karsten.
Karsten Saenger
VincentSheehan
Ok. I just reinstalled C3D 2025 and everything works. Thanks for the help.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
VincentSheehan
I discovered it is the Civil 3D Profile causing the IMX file not to import. The company I work for uses a custom profile. When I use the <<C3D_Imperial>> profile, it works. I'm running a comparison on the two profiles to see what has changed.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
VincentSheehan
It's a 3rd party pipe catalog causing the issue. When I remove the catalog from the Pipes Catalog folder, I'm able to import the Infraworks model.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
