Civil3d failed to import my imx file
hamidatut72
hamidatut72
Hello guys. I am working on my design in infraworks. Now I want open it in civil3d. but it didn't open my file and showing the bellow pic. error. either the other solutions in forum do not work in my case. I will share my imx file to mytransfer link. so if anybody can help. thanks...
https://we.tl/t-SiJU9bUI2C
Replies (10)
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @hamidatut72 ,
I can confirm the error with your IMX file when importing it into Civil 3D on my side.
I believe the IMX is corrupt for some reason.
Please open a new InfraWorks model and load the IMX file there. Then export as IMX again.
The IMX I exported my own did import fine into Civil 3D.
Karsten.
Karsten Saenger
hamidatut72
I Can Import All Of My Imx Files Except This One. I Should Say That I
Exported My Alignments From C3D To Infraworks And Designed My Interchange
In Infraworks. And Now It Can Not Be Imported To C3D. Is It Because Of Its
Complexity???
FrankHuang
@hamidatut72  which version of Civil 3D and InfraWorks are you using?  In this IMX file, I need to check design roads instead of component roads in order to send the data across?
Hope helps,
Frank Huang
Autodesk Infrastructure Product Owner
"https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png"
hamidatut72
Both Are 2020.1
FrankHuang
@hamidatut72  we checked the imx file, it is created from InfraWorks 2020.0, not in 2020.1.
to make it work, could you please make sure to install InfraWorks 2020.1, then then export the IMX, then import to Civil 3D 2020.1. It should work.
Hope helps,
Frank Huang
hamidatut72
Thanks For Your Attention. I Am off Today. I Will Check It Tomorrow at My
Office
hamidatut72
Hi again, my C3D is 2020.4 and Infraworks is 2020.0.25. But after all when I just deleted the designed roads, I can import the imx file. I think it's because of my road geometries. I'll attach my sqlit file here by a wetransfer link, see if you can give me a C3D file. thanks
https://we.tl/t-7JX8SqO8b2
hamidatut72
I've tested some ways. I had a bridge design in The file, So when I deleted The bridge design, the  imx file works properly, I just don't know why!!!!!!!
Mohamed-Nassar
Have you check your coordinate system
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
FrankHuang
@hamidatut72  It is a bug of the software. I logged it in. If you are not using latest version of InfraWorks, you will meet this problem.
The issue happens when version of Civil 3D  is >= 2020.1 and version of InfraWorks <= 2020.0.
To fix this, you will need to update your InfraWorks to latest update of 2020.
Hope this helps
Frank Huang
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
