InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Error importing C3D dwg
2 REPLIES 2
schambers
573 Views, 2 Replies
Cannot connect to 2021 C3D file.
Log file attached
2 REPLIES 2
Karsten.Saenger
in reply to: schambers
Hi @schambers ,
I'm not sure if I read the log files correctly, but it looks as the IMX creation and loading into InfraWorks fails.
When you import a Civil 3D DWG into InfraWorks, the DWG is converted to IMX in the background.
Can you save the DWG and close Civil 3D before importing the DWG into InfraWorks? Does this work?
If not, does it work if you export the DWG to IMX manually in Civil 3D. Then import the IMX file into InfraWorks, just to test if there are errors or not.
Karsten.
Karsten Saenger
schambers
in reply to: Karsten.Saenger
I downloaded 2022 versions of both programs and seems to be working now
Rail Community
