Enable to open model
jean-christophe_ouaknine
With InfraWorks 2023 (23.1.0.18)
I try to open different model (from different types : shared on ACC, a sample or from Model Builder).
InfraWorks return the message : "enable to open model".
I try to change the local path for A360 and Cache folder to another pathfolder : C/DATA/InfraWorksModels/A360 & Cache.
It doesn't change the problem.
Please find attach the log file.
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @jean-christophe_ouaknine ,
did you install InfraWorks 2023 just recently?
There are two possible reasons for your issue:
  1. The model path is pointing to a cloud drive (i.e. OneDrive) or server
  2. The previous InfraWorks was incorrectly uninstalled.
It looks like your models are located in a local drive. So, I suggest a clean uninstallation and reinstallation of InfraWorks.
-> https://knowledge.autodesk.com/article/Clean-reinstallation-of-InfraWorks
Karsten.
Karsten Saenger
Hi Karsten
as it's described in your link solve my problem.
Thank you.
Hi @Karsten.Saenger
me and IT service have to prepare many computers
The solution you perpose solved the problem on many computers,
But on one computer, a new messsage appears, blocking installation :
Do you have any idea ?
Karsten.Saenger
Autodesk Support
Autodesk Support
unfortunately, I don't have an idea what the issue is on this specific computer.
I suggest creating a support ticket for the Autodesk Installation Support. -> https://www.autodesk.de/support/contact-support
Karsten.
Karsten Saenger
