Solved by ToddRogers-WPM. Go to Solution.
Not sure what you're referring to as "conceptual". There are 2 kinds of roads in Infraworks; component roads and planning roads. If you are referring to a planning road, then no, you can no longer change the width of the road. However, you can right-click on it and convert it to a component road, then change the width.
