InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Does Infraworks calculate eathwork quantiliies (cut and fill) of grading area?
2 REPLIES 2
sukishum20
287 Views, 2 Replies
I am from an urban design background and we are exploring the possibility to use Infraworks during our design process.
I acknowledge that earthwork quantities / cut & fill of a component road can be calculated. Does the earthwork quantities function only apply to the component road? Can we also use that when we draw a grading area to see its cut/fill volume?
Component road earth quantitiesComponent road earth quantities
I can see in the proposal under grading areas, area change is shown comparing to the last proposal, but that is not cut and fill.
grading area - earth quantities function?grading area - earth quantities function?
Thanks in advance, it would help a lot if this function is actually available.
2 REPLIES 2
Matheus-Lima
in reply to: sukishum20
Hello @sukishum20, welcome to the forums!
Yes, there is a tool called Terrain Statistics for it. Actually, it would be nice to have some updates on it and make it available to export the results in a csv like in the component roads. But here it is, I hope it helps: https://help.autodesk.com/view/INFMDR/ENU/?guid=GUID-27C4105B-983B-44A8-BDBC-2C0D09F8CDF7.
On the topic, take a look at this thread. Karsten made it simple to understand how the terrain statistics tool works: https://forums.autodesk.com/t5/infraworks-forum/imported-shp-file-as-land-areas-shows-0-cut-amp-fill....
Cheers,
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
sukishum20
in reply to: Matheus-Lima
Thanks for your reply @Matheus-Lima, this is what I need! Hopefully, there will be an update soon exporting this data to excel, this will save us so much work!
Rail Community
