This seems like an easy one but I can't find the solution. Is there a way to control which style gets applied to a road when importing alignments from a Civil 3D file?
It does not seem to use my active style. It does not seem to honor the style you select when configuring the data source.
Can you try Data Sources>right click on imported road on list and Configure>Common>Style>Assembly Stlye?
I have ta similar question too. I just want to know what default style is used. I like the default style that is applied but I wish to change the road material.
I think I have applied every single road style to a sketched road to try and find out the default style but none of them match. The default Rule Style says <Empty> and the Manual Style and Rule says None when selected. There are no entries in the Properties Panel for Manual Style and Rule Style either.
