Announcements
Cul-de-sac
oriole_phillips
Cul-de-sac
oriole_phillips
Any know of an EASY quick way to add a cul-de-sac at the end of a road? This would be a great idea to add to the next Infraworks update. Including a radius option.
Replies (14)
JasonArtley
I'm pretty sure this is a pretty heavily requested feature, but there isn't an easy way quite yet that I am aware of. There's this blog post that shows one way: HERE and I've used that before with success.
Most of the time though, if I'm doing a "quick and easy" cul-de-sac, I just do a 4 point "diamond" on the end of the road. You can change styles as shown on the blog link to remove the inner circle. Sometimes I'll just put a tree in the middle to make it look intentional! Maybe in the next couple releases they'll have this feature sorted out. I would imagine a modification of the roundabout coding could make it possible.
ToddRogers-WPM
A coverage area is the only way.  I have been pushing for this for 2 years now.
Edited....replied at the same time @JasonArtley did.
Todd Rogers
Eduardo.Soethe
There is a pending idea on IdeaStation, but I do as follows.
I create an alignment through the gutter and I apply a section, only gutter curb and sidewalk.
In the interior of the cul-de-sac, I apply a coverage area
If you have some difficulty to creating a more precise alignment, make in Civil 3D and export to your Infraworks model.
Eduardo Soethe Cursino
Civil Eng. | BIM Specialist
Soethe Cursino Consultoria | BIM for Infrastructure | LinkedIn
Autodesk Certified BIM Specialist: Road and Highways Solution
AutoCAD Civil 3D Certified Professional
__________________________________________________________________________
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma reposta e Kudos de gostou.
Autodesk Community
oriole_phillips
Great idea, thx
oriole_phillips
Great idea for proposd roads.
Eric_Chappell
@Eduardo.Soethe a Screencast showing this workflow would be a big help!
Eric Chappell
ToddRogers-WPM
Yes! I second what @Eric_Chappell mentioned. Maybe post it on the Knowledge Network?
Todd Rogers
Eduardo.Soethe
@ToddRogers-WPM @Eric_Chappell
I will make the video.... I had forgotten
Autodesk Community
Yoffre_Vargas
@Eduardo.Soethe PLEASE CAN SHARE THE LINK
Yoffre_Vargas/Educator_Expert/ECUADOR
Si mi respuesta solucionó tu problema, por favor, márcala como Solución Aceptada y haz clic en Me gusta.
Todd my brutha! Did you ever get a link to a video of how to do this particular culdesac?
ToddRogers-WPM
Hey dude! No, it was never posted. @Eduardo.Soethe, did you ever do this?
Todd Rogers
Yoffre_Vargas
https://knowledge.autodesk.com/es/community/screencast/ed0a6713-9c59-4cda-8824-4831a1c426f7
YOFFRE VARGAS - ECUADOR
correguido
Usa aceptar como solución o kudos si la respuesta dada resolvió tu problema
Eduardo.Soethe
Hi guys sorry for the delay in answer.
I did a sequence of images and hope it helps.
Captura de Tela (1).pngCaptura de Tela (10).pngCaptura de Tela (3).pngCaptura de Tela (4).pngCaptura de Tela (6).pngCaptura de Tela (7).pngCaptura de Tela (11).pngCaptura de Tela (12).pngCaptura de Tela (13).pngCaptura de Tela (14).pngCaptura de Tela (15).png
Autodesk Community
Eric_Chappell
This post has been featured on the Autodesk Civil Engineering Community Center http://civil-community.autodesk.com/2018/03/infraworks-forum-post-week-cul-de-sac/
Eric Chappell
