InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
CS
2 REPLIES 2
mamilla_nagesh
134 Views, 2 Replies
CS
wgs84 utm 46N is not showing in Infraworks
2 REPLIES 2
Hi, @mamilla_nagesh!
I would try the category of Coordinate Systems named UTM, WGS84 Datum.
Hope it helps,
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
Thanks Lima.I have entered UTM84-46N directly and it worked .However i will try UTM,WGS84 category
Rail Community
