Coverage and lines
Coverage and lines
Coverage and lines
I'm quite new at using Infraworks, so pardon me if my question seems stupid.
I've established my model with a terrain model, draped an orthophoto and imported my road. Beside the road I want to fill the areas with coverages - for example grass. Everytime I'm drawing an area with coverage (randomly picked) the polygon visualizes with randomly lines along and across the polygon (see attached jpg).
Is there a way to remove the lines? And why do they show up? I've seen some tutorials on youtube, and I've never come across the same "problem".
The same happens when I'm drawing a tree line with city furniture (see jpg2 #2).
Thanks in advanced.
- Thomas
Edit: By the way, I'm using Infraworks 2018
Todd_Rogers
This is pretty normal. Do they go away when you click somewhere else in the model or hit the ESC key?
Todd Rogers
Civil Administration at Walter P Moore
kathy.feng
These lines are used to highlight sketched feature in drawing mode. They can be removed by switching off 'Highlight Sketched Features' in the 'View Settings' -> 'Interaction' tab. Detailed steps are recorded at  http://autode.sk/2ykMU92  for your reference.
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Kathy
Thank you for your help! It solved the 'problem'.
Thomas
