I create shapefile with polilne, them drape on my road .
I want convert this road to design road, but when I convert road to design road- it's look's bad.
I want create a patch camera form this road exactly same like my shapfile poline ( it's 38km....end i rly don't wany crate my own road.... )
Before
After :
What to do ?
Solved by Karsten.Saenger. Go to Solution.
Hi @Anonymous
I do not fully understand why you are creating a design road ot of the shape file.
Am I correct that you have a road already and you want to create a camera path to follow the road?
If I am correct, why don't you use the shape polyline directly as a Camera Path?
See InfraWorks 360 Help: To import point data as a camera path
Converting geomtry to design road will also change geometry in some grade.
Karsten.
I tried to use tihs tool ( on this topic http://forums.autodesk.com/t5/infraworks-360-general/camera-patch-from-sdf-file-fail/m-p/6444755
I explain another problem... )
This project it's little difficult. 1st I created road in civil 3d.
In INFRAWORKS I only have coverage area end surface TOP from road.
If will be possible to use, this polilne from camera patch will be graet, but I need something thing to do :
- distance to target
- horizontal offset
- verticsal offset etc
On this simple tool like importing camera patch - I dont have this thing's.
Edit :
Other problem it;s created shapefile 3d from polilne - when i try import to INFRAWORKS i get this message :
shot details :
The selected file does not contain point geometry......
It's polin3d with geometry points and Z elevation.
Hi @Anonymous
I do not agree that you must use SDF format only for a camera path import, like you mentioned in the other post. Shape, db and sqlite formats are also possible.
I agree that camera settings in InfraWorks are limited. If you like to have full camera control you will need to export your model and import it as 3D file into 3ds max for example.
When you say "it looks terrible" what does look terrible exactly, for example is it not smooth?
The points of the path are used as keyframes and the program interpolates the distance between the keyframes. If it is not smooth enough try using less points.
See also http://knowledge.autodesk.com/article/InfraWorks-Camera-path-along-curves-is-choppy
How about this workflow:
karsten.
Yes, i do exactly the same that u wrote...but no successs
There u can get my dwg file inc. cogo point
http://www112.zippyshare.com/v/WtqkgI6I/file.html
i EXPORT to SDF file them bring camera patch as well and :
I try many other setting but "horrible loks " is
https://www.youtube.com/watch?v=qKubBwzOrm4&feature=youtu.be
ok seem's that we solved problem
Keyframe expreesion must be changed : not autogenerated but from point 1-2-3-4-5
Autogenerated create camera patch 1-10-100-30
And we must add Geometry Z
Exporession is : elevation +1
Hi @Anonymous
I have created a screencast og my workflow - it's one of various was to create a camera path for InfraWorks.
Notes:
THX !
I wrote yesterday that I solved problem, the key to the solution my porblem is your screencast from 2:40.
Greet.
