how do i convert a component road to a planning road
Solved by VitorSouza_MAPData. Go to Solution.
Hi @asvillavieja ,
Currently I don't believe it is possible to convert from Component Road to Planning Road, only conversion from planning to component is available.
Hi @asvillavieja ,
Hello.
It is not possible to convert a Component Road to a Planning Road because these are project stages, from the moment you decided that you should convert a Planning Road to a Component Road, it is because you understood that that was the necessary Layout For your project, it works the same as the phases of an architectural project: Preliminary study - basic project - Executive project. In other words, you need to delete this Component Road and create a new planning road.
Hello.
Thanks.
