Component Roads Opacity
hi,
is there a way to change the opacity / transparency of a component road so i can show the utilities i have done below the ground?
thanks
erick
Accepted solutions (3)
SethHall
Hi Erick-
You can change the material of the components in the road to a color then adjust the alpha to control the opacity. Once you have it setup the way you want you can add the components/assembly to you local library.
Let me know if that helps!
Seth Hall
Product Owner
Model Builder
hi Seth,
I will try this one and thanks for the prompt reply. im a newbie on IW360 and just had one week experience but thanks.
hope this works I will keep you posted and might come back to you with more questions in case it does not work.
erick
hi Seth,
im not sure if im doing it the right way, I can change the material to a color but can't seem to find a tool or button to adjust the transparency.
I have played and ventured around with IW360 and still no luck.
can you direct me (step by step if possible) to this process?
thanks.
JasonArtley
The transparency is kind of hidden. There's a spot to adjust "Alpha Channel". Change this from 0-255. 0 is completely transparent, 255 is completely solid. I usually with 50 and adjust from there. Good luck!
SethHall
Hi @Anonymous-
Unfortunately you cannot control the alpha of the materials, you have to select a color form the color palette:
Seth Hall
Product Owner
Model Builder
thanks for the response guys. yeah I have trouble finding a way to modify a component road to make it transparent.
the only way for me to show it is to strip off the component of the actual road and retain the parking, kerbs and sidewalk and make an offset
from centerline and then replace the actual road with a transparent road.
I wish autodesk can incorporate a transparency material to any type of road, be it a design or component road.
thanks again for your help!
