Hi guys,
I am making a design for a client and now i want to make the asphalt dark black. But somehow, when i pick the asphalt from the library, it makes it a little bit green and transparant
and transparant, because i can see the lower part of the tankpit, which is underneath the ground:
Does someone has an idea how i can make this coverage dark, not transparant, black?
Thank you in advance!
Friendly greetings,
Luke
Hi @Luke.vansonsbeek ,
which material did you pick from the style library?
Can you send a screenshot?
Karsten.
Dear Karsten,
I tried multiple things, creating my own color:
And the standard "asphalt" out of the catalog:
When i make the contrast of the view settings higher, the colors are appearing black, but then the other parts of the model do not look nice anymore.
Friendly greetings,
Luke
can you change the "surface opacity" to "100" and let me know if it solves the issue?
Karsten.
