Change Texture Based on Attribute
jaronkDDX26
jaronkDDX26
I have a .shp file that has attributes on whether or not it should be displayed or not (the attributes or either blank or SHOW). I was wondering if there's a feature to assign a texture based on that attribution. Its a .shp file polygon that I will be bringing in as a coverage area
Is there a way I can write an expression for this?
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @jaronkDDX26 ,
you can use "style rules". Based on attributes, different styles can be applied. For "don't show" use a transparent style.
Help | To define style rules
Karsten.
Karsten Saenger
