I have a big project (60km) with 80 bridges an 12 tunnels on it. I need all of this data (bridges and tunnels) to move on another alignment. How can this be done in Infraworks?
Thank you!
If you have created the alignment in civil 3D, I think if you edit that alignment (not make new), and reimport into infraworks. It might work.
It was indeed created in C3D. The solution that you proposed may work but the problem is that the alignment should be imported from other dwg and with different name (the geometry is the same). The infraworks model is very advanced with a lot of element in it and and it will be a lot of work to start it from zero with this new alignment. For us will be very helpful a possibility to change the alignment.
Hmm, One thing you can try to do. If the location of the alignment is same. I suggest renaming the alignment as its named in the other file and then in infraworks from data sources, reconnect the dwg file but this time by selecting the new dwg. Maybe this can work.
