I have been searching for the 'Infrastructure Modeler plugin 2024,' but I couldn't find it. I tried almost everything, but I failed. Can you guys tell me where to find it?
Solved by Karsten.Saenger. Go to Solution.
Hi @diaa_maa ,
is it the "Inventor Infrastructure Modeler Plugin 202x" that you are looking for?
If yes, you can load it from the Civil 3D Extensions, but it's not released yet.
If you keep the installation order 1st Inventor, 2nd InfraWorks, it should be installed automatically, see Autodesk Civil 3D Help | To install the Infrastructure Modeler plugin .
Please let me know if it works for you.
Karsten.
Thank you so much. I was searching under InfraWorks extensions, but I found it under Civil 3D extensions.
