Can not extend model
Message 1 of 14
Dear everyone,
After Designing in Infraworks, I need to extend the model abit. And I am wondering why it was not updated.
Is there some thing wrong or it just can't be changed?
Many thanks.
Replies (13)
Message 2 of 14
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous ,
is there any data available that is in the extended area?
If you download a Model Builder model, the model has
  • A: a defined extent
  • B: downloaded model data only for the given extent
If you extend the model later, the extent is large, but there is not automatic download of additional model builder data. This meens, you need to add your own data manually, especially the surface.
Karsten.
Karsten Saenger
Message 3 of 14
Dear @Karsten.Saenger ,
Thanks for your reply.
You mean If I create model from Model Builder. I can not extend it later.
Can you have look at this video.
https://knowledge.autodesk.com/support/infraworks/learn-explore/caas/screencast/Main/Details/5b564ec...
Message 4 of 14
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous ,
yes, the model extension in this screencast works, because the actual model size is not "entire model".
This means, that the model was reduced in display size before. In this case the data sources are existent and available for extension. But it won't work if you make the model larger than the initial "entire model".
Karsten.
Karsten Saenger
Message 5 of 14
Thank you,
That's clear enough.
Message 6 of 14
kwilktrihydro
Hey, you actually can make it work, I did it just today. I had a model where I had +100 features already placed and didn't want to bring everything into a new model (I had a lot of "furniture" I created in 3DS Max). What you need to do is export a shapefile for your desired extent. Then, go into your model properties and change your model extent by clicking the "Load Extent From File...". Once your model extent is changed, create a new Infraworks model with the desired extent. Now that your new model is created export the model as a .IMX file. Once exported, go back into the model you want to expand and bring in the .IMX files (you may want to erase the existing terrain, water, roads, etc. from your model). This .IMX file will bring in the roads, water, and most importantly, the terrain for your desired extent. Finally, you will want to right-click on the Infraworks provided imagery (Bing) in the data sources and click configure. When you click "close and refresh" your imagery will update to cover the "new extent" of your model.
Hopefully that all makes sense, it sounds long, but the process goes relatively quickly. Much quicker than trying to rebuild a giant model anyway. Let me know if you have any questions!
Kelby Wilkison, P.E.
Civil Engineer
Trihydro Corporation
Message 7 of 14
Hi @kwilktrihydro ,
I have tried as you suggested and I can confirm it works.
Many thanks,
PhamD.
Message 8 of 14
Karsten.Saenger
Autodesk Support
Autodesk Support
Nice workaround, @kwilktrihydro !
Karsten
Karsten Saenger
Message 9 of 14
marie-pierre.lebel
Although the ground imagery doesn't follow through in the IMX format...
Message 10 of 14
kwilktrihydro
Hey @marie-pierre.lebel ,
That's correct, the imagery doesn't come through in the .IMX. I stole this from my above work around. "The .IMX file will bring in the roads, water, and most importantly, the terrain for your desired extent. Finally, you will want to right-click on the Infraworks provided imagery (Bing) in the data sources and click configure. When you click "close and refresh" your imagery will update to cover the "new extent" of your model. " In other words, once you refresh the image data source, your imagery should update to your new extent.
Civil Engineer
Message 11 of 14
it work for me in 2021 version, I need to dray my Terrence into the Ground cataloged and then refresh the Ground Imagery in the Data Sources. Thanks
Message 12 of 14
Good afternoon Mr. Wilkison,
I was looking at your fix for expanding the model area. Does the new model you create have anything in it other than the extent, as I would have to use an expanded terrain and image that I will have to create. Also if you import the IMX into that model and it has the old data coverage will it overwite an updated terrain and image, and for other data can you just delete those layers and replace them with newly extended versions (eg. watercourses, etc.).
Robert
Message 13 of 14
AlejandroIturriaga.B
I wasn't able to replicate this. Where should I export the shapefile from? I appreciate the help.
Message 14 of 14
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @AlejandroIturriaga.B ,
Shape files can be created with Civil/Map 3D and the command MAPEXPORT.
You can also use any other GIS program, for example, QGIS.
Karsten.
Karsten Saenger
