Can coverage laid on top of grading area
namlt33
namlt33
I have a graiding area zone, now i want create some kind of road marker (pattern on the ground) on that area with coverage. But the coverage keep be hided by the grading area. Is there any way i can fix it?
VincentSheehan
Do you have a Material/Color assigned to the Grading Area? I'm working on a project where I have the Grading Areas set to Transparent and have Coverage Areas in areas such as pavement, road striping, grass, and so on. I hope this helps.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
namlt33
yes my graidng does have material assigned, do you any ideal how to show the Coverage in this case sir?
VincentSheehan
Set your Grading Area object to transparent then you should be able to see the Coverage Areas.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
