Hello Infraworks Community,
I have a project in a modified state plane that I am having troubles getting a surface moved into my Infraworks Model in State Plane.
I have a surface that I have used that merges the surveyors existing ground with my proposed ground. The goal of this is to try and bring in the surface into Infraworks and have it displayed on top of the Bing Imagery that I have to show the client what this looks like.
So here’s all I did:
Any help you can provide would be beneficial. Please see attached drawings.
I am using Infraworks 2018.2
Solved by mzjensen. Go to Solution.
Hi Sean,
This is an interesting case. I frequently deal with modified state planes grids, but I've never seen the coordinates truncated like that! Anyway, it seems like your approach should've worked and I'm not sure why it didn't. I tried another method and was able to get it to show up in the right spot in InfraWorks. Here are my steps:
Some other things to note. First, I am using IW 2020. In the Surface Layers window, I had to move the imported surface to the "Ground Surface" category and turn the lightbulb on in order to show the surface (see attached screenshot). I don't think 2018 has these same options, but maybe check them in your model to see if anything is wrong. Also, the surface came in quite a bit lower in elevation than the USGS surface from model builder. You can see that in the screenshot. I didn't look at your control points file, but it may be an issue of different datums.
Finally, if you're wanting to bring in coverage areas from CAD to drape on the terrain (i.e. textures like asphalt, concrete, etc.), then they will come into IW in the wrong spot if you just use the state planes grid. Those transformation settings that we applied earlier are embedded in the IMX file, but they won't be embedded in SHP or SDF files if you go that route for the coverages. So what I've typically done is put an X and Y shift in the data source configuration for the coverages so they move over to match the surface. I've attached a screenshot from CAD with the approximate values that you'd need to use.
Thank you so much for your help with this. I regularly deal with these modified coordinates and these large truncations on almost all of my projects. I did your steps and that worked, so thank you.
This is the first time I read a post about this process and i works great. Using your transformation settings, I can use this method anytime (which is often) I'm working in ground coordinates and using the Geolocation map. I use to shift the map using a convoluted way, but your method is far more proficient. Thank you.
