InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Box Girder shows solid after publishing Bridge to Revit
3 REPLIES 3
dennis.sangalang
643 Views, 3 Replies
I have created a parametric Box Girder that I can manipulate varying thicknesses of Web & slabs and with Diaphragm in Infraworks but after publishing to Revit, it shows solid. Hallow portion of Box Girder doesn't appear in Revit. Please see screenshots below.
Does anyone can help me solve this matter? Thanking you in advance.
Infraworks- Box Girder showing varying depth and thickness of slab
Infraworks-Inside Box Girder showing Diaphragm 
Revit-Sectional elevation showing solid girder. Supposed to show slab thicknesses and Diaphragm.
Revit-Section showing solid girder. Supposed to show slab thicknesses and Diaphragm. 
Inventor - created parametric single cell  Box Girder
Labels (1)
3 REPLIES 3
jim_geer
in reply to: dennis.sangalang
Hi @dennis.sangalang
This is a custom box girder that you created in Inventor?  or is this one of the box girders that comes with Infraworks?  Which version of all of the products are you using?  Would you be willing to share the IPT here?  I can take a look at it and see if I can figure out what is going on.
Jim Geer
Principal Software Engineer in Test
dennis.sangalang
in reply to: jim_geer
Hi @jim_geer ,
Thank you very much for your response.
I sent log this query to Autodesk Helpdesk & sent all the files that they requested.
I was inform by Autodesk Customer Service that you are looking into my query.
I am very excited for this issue to be resolved and  show to our organization the power of infraworks for varying properties of box girder for bridge.
Dennis
Dennis
dennis.sangalang
Hi @jim_geer ,
The issue has been resolved. Thank you for the updated file you sent.
I understand, I might need to split the feature in inventor to make work.
Rail Community
