Bing Maps Problem
Bahram_Afandi
Bing Maps Problem
Bahram_Afandi
Hi everyone!
I'am new in this software and I have some problems with raster. Bing Maps section is not displayed in "Connection Type". Image attached
Thank you for attention!
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Bahram_Afandi
what coordinate system (CS) is defined for your surface?
What CS is defined as database CS (- see Model Properties)?
Karsten.
Karsten Saenger
Bahram_Afandi
@Karsten.Saengerwrote:
Hi @Bahram_Afandi
Karsten.
WGS-84 UTM-39N
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Bahram_Afandi
thanks!
Close look to your screenshot revealed that you are working with InfraWorks 2015, correct?
Please upgrade to the latest version of InfraWorks and you issues should be solved.
Karsten.
Karsten Saenger
Bahram_Afandi
Hi @Bahram_Afandi
thanks!
Karsten.
Thanks a lot! Solved..
