Barra de Herramientas no se ven los iconos
ruiz
ruiz
Hola
No se puede ver la barra de herramientas, se ven cuadritos negros en toda la parte superior.
Gracias
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @ruiz ,
do you use a docking station and/or you connected your computer to your monitor with a VGA cable?
If yes, that could be the reason for your issue.
Make sure you use a HDMI or DVI cable to connect to your monitor.
Other possible reason is that InfraWorks uses an onboard graphics adapter that is not capable to be used with InfraWorks. Make sure you use the more powerful graphics card if you have installed two.
Karsten.
Karsten Saenger
ruiz
It´s works. Thanks,
