InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Augmented Reality
24 REPLIES 24
Message 1 of 25
sconroy
3282 Views, 24 Replies
Augmented Reality
I've been trying to find a suitable platform for augmented reality and have been hitting a wall. Everything I've read seems to indicate that autodesk with the Ipad app had a possible solution that it is no longer available.
Does anyone have any feedback on software / processes to get my Infraworks model to a platform that can be viewed on site?
Sean
Dell precision M6700 Intel Core i7-3740QM CPU @ 2.70Ghz -16GB RAM Windows 10 Pro - 64Bit
NVIDIA Qardro K4000 video card dual monitor setup
Civil 3D 2019.3.1 w/ AutoCAD 2019.1.2 / Infrastructure Design suite Premium 2019
24 REPLIES 24
Message 2 of 25
ToddRogers-WPM
in reply to: sconroy
You have come to the right place. See link below...
https://www.torch.app/
Todd Rogers
Message 3 of 25
sconroy
in reply to: ToddRogers-WPM
@ToddRogers-WPM Thanks for the lead on that, I'll investigate the app further.
Having said that, one of the biggest problems I've encountered with any AR solution is how to geo-locate an interface (like a tablet/ Ipad) with a certain amount of accuracy vertically. I'm thinking that this may require some survey equipment to do and am open to this possibility.
Any suggestions would be appreciated.
Sean
Message 4 of 25
ToddRogers-WPM
I am tagging @Matt__W . He is a genius at this.
Todd Rogers
Message 5 of 25
Matt__W
Welp.... unfortunately, as we all know, the iPad app is dead. The good news is that Tony, Josh and Paul from Torch were at AU this past November and got an earful about the need for an InfraWorks geo-located AR model. Now, whether or not they develop something (or better yet, team up with Autodesk) is another story. (Fun fact: The guys from Torch have been to Autodesk Portland at least one time so who knows. Anything is possible) But they're definitely open to developing something like the old iPad app. They've seen and understand the need for it. Someone at AU actually still had the app on their iPad and was able to show them exactly what it was all about.
Hopefully something comes of all this.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 6 of 25
JamesMaeding
in reply to: Matt__W
@Matt__W
Wow, just saw this thread after trying to find the IW 360 that surely was on Android by now.
Nope. Guess I'll have to go to other vendors.
I saw the xyht article here and thought for sure that was some updated Autodesk product until I read it.
thx
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Message 7 of 25
sconroy
in reply to: JamesMaeding
@Matt__W
if you do come across a solution, please share...
Sean
Message 8 of 25
JamesMaeding
@sconroy
I'm thinking the vGIS platform, at like $100 a month per user, is the best I have come across.
I only read about it, but its seems that people are essentially making Unity games and hooking them with AR mechanisms. The software Revitzo does this too.
Message 9 of 25
mzjensen
Not sure what your budget is, but you could look into Trimble SiteVision. That would give you GPS accuracy.
Zachri Jensen, PE   |
Message 10 of 25
JamesMaeding
in reply to: mzjensen
@mzjensen
great tip, that looks so cool. Not too expensive either at $5k first year and $2k after.
thanks!
Message 11 of 25
rich_reactar
Hey team.
We've been working on an augmented reality app for residential construction. Currently for simple design visualisation at small and full scale, but lots more we're working on.
We're in beta in NZ right now but if you're keen to give it a try just go to https://www.homear.io/download. Our sample project is here.
Not sure if it fills the gap you guys have been discussing. Shout if you have specific needs and we can talk about it.
Looking to talk to Autodesk about integration but for now it's a 3D export (FBX, GLTF, 3DS etc) and processed for AR at our end.
Cheers
Tags (1)
Message 12 of 25
JamesMaeding
in reply to: rich_reactar
@rich_reactar
I've looked at a few so far and the issues seem to be how the data is loaded and served to the apps.
When they work, it all looks great. There always seems to be some issue on the ones I have seen so far though.
Some are made for GIS systems, some need expensive GPS receivers.
One interesting issue is what the app considers the ground. If a site is already graded, the online services like Bing will not have that surface.
My thing is I want to be able to define a custom ground surface and existing imagery, essentially what Infraworks does.
Then I want to add solids from dwg or fbx. I don't really want to use an online data system like BIM 360 or similar. I have no problem uploading my model to the cloud, again, like Infraworks, but I need to be able to model thing in some desktop environment, then see in AR.
Message 13 of 25
@mzjensen
I've used Trimble Sitevision for this, and have tested it first-hand to check the accuracy of geolocated content. It's very good.
I pulled content from Infraworks through into Sitevision, using the IFC format. Subsurface features with full object attribution, buildings .etc
I didn't test textured surfaces, however I'd say it'll probably work fine. Just be sure to optimize the data appropriately for AR / Mobile use. I think 5 million Polys might be the current upper limit?
The challenge in my estimation is writing the IFC correctly to make use of all its capabilities.
AEC Collection / Safe FME / ESRI ArcGIS / Unreal Engine
Digital Engineering Lead, Compulsive Problem Solver.
Message 14 of 25
@andrewofabley
How did that go with simple solids from acad?
We wrote our own civil 3d modeling tools, and end up with solids and native entities.
I have not used IFC. I have used IMX which is generally for cvil3d items like surfaces.
Is there a workflow you saw for regular acad solids? thx
Message 15 of 25
@JamesMaeding
I believe it would work fine for solids - I created my IFC from GIS data such as pipe networks and building footprints, simply by extruding / sweeping them. I didn't actually perform this operation in AutoCAD, but I anticipate it being no different (although in my experience, the topology is a tad rough from AutoCAD). The resulting geometry looked identical to that which I could create in Civil 3D. Given that Trimble Sitevision accepts this file format, it's certainly worth a go.
I found using a format agnostic spatial tool such as FME to automate this made it a lot less stressful (and not manual). That let me form all my 3D geometry based on the attribution data - call it semi parametricisim.
That said, I believe this would convert over fine from Civil3D, depending on the output format from Civil3D. Obviously retaining rich attribution for viewing was very important for GIS data, so we went to IFC for this reason.
Message 16 of 25
@andrewofabley
The thing is, I already have highly automated tools in acad to make the solids from civil engineering data.
So wondering if your platform handles those, direct from .dwg.
Its the details that have hung everyone up on this. Try on a couple 3d boxes and swept solids drawn in state plane coords.
thx
Message 17 of 25
@JamesMaeding
I've tested this and can confirm that the process does work for regular AutoCAD solids. I imagine it would work for Civil3D surfaces too. I haven't done this in a particular projection, however I could if necessary.
If you had some test data, I could run it through and see what pops out.
Message 18 of 25
mzjensen
in reply to: andrewofabley
@andrewofabley- I've been wondering how well it works, so thanks for confirming.
I'm curious how you got from InfraWorks to IFC?
Zachri Jensen, PE   |
Message 19 of 25
andrewofabley
@mzjensen
I have some sophisticated ETL software, within which I build these custom workflows 😉
I'll either read the Infraworks sqlite database in, or use 3D model exports.
I can then write into the IFC schema, apply attribution and optimize the 3D geometry, and make sure all the spatial referencing is shored up.
When loading into Trimble SiteVision, everything comes through nicely. No manual positioning or mucking around.
Message 20 of 25
mzjensen
Gotcha. Very cool.
Zachri Jensen, PE   |
Rail Community
