Hello, I'm kind of new in infraworks. Does anyone know how to add radius to a stream? The only option available is to add vertices
Solved by ToddRogers-WPM. Go to Solution.
You have to use vertices. If you create a shapefile in Civil 3D, you can bring it in as a water coverage, but the curves will have several vertices.
