2d overlay empty....
hi  agian,
What i  doing wrong, i  bring a 2d overlay dwg file to  infawork, but nothing happens, i  can't modyfi this file ..
why no thing to confugure ??
lippola
hi,
once you import the DWG file you need to place it via the positioning grips. If you select the overlay in the datasource panel you see it attached to the mouse pointer as a ghost copy. Now you can select a point in the model and a point in the dwg file to reposition it.
Let me know if you can see the dog file somewhere in the model.
In the model explorer you can set the transparency and the stacking order of the overlays.
Andreas
it's wird
i  waint couple minutes end start work....
But how to move this layer behind ?
In layer i  dont see any land area -  i cant hide this...
lippola
hi,
out of your screenshot i cannot see if the status of the overlay import is still processing? If so how big is your DWG file?
Can you send a screen shot of the Dialog again as well as how the DWG file looks like?
What do you mean by "How to move this layer behind"?
Thx
Andreas
I mean how simple hide this overlay in infawork, becouse this land coverage cover all project.
Now i can't   select any road or anything else.
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous
yopu can switch on and off your 2D DWG overlay in the model explorer.
If you have several overlays, you can adjust the draw order there as well.
Other than that, there is currently no way to control the layer order in relation to other objects, for example via the Surface Layers.
Karsten.
Karsten Saenger
