- Mute
- Permalink
- Report
I am trying to import 2d AutoCAD drawing with a geolocation into InfraWorks.
I explode all the elements from 2d drawing into lines and then export shp file. I create a new coverage style in IW360 with fill style but without outline.
I import shp file, choose coverage type, rule style that I created, in Source tap I tick off "Convert closed polylines to polygons" and in Draping Options choose Drape. Click Closerefresh then select the features in data sources window and in Geometry tap i change buffer to 0,1 m.
After all these operations some of the elements from map are visible, but some of them are not.
I attached my model and 2d drawing. Can anyone try to repeat my steps and figure out why I cannot see some of the lines?
Link to InfraWorks model: https://www.dropbox.com/s/3ij8f6epe4gxe66/239230.zip?dl=0
Coordinate System: ETRS89.PolandCS2K-6
