Hi all
Does anyone know if there is a way to change the size of the terrain tile when exporting FBX files from IW 360?
The FBX export settings produce tiles (and relevant jpg aerial photos) of 512m square, i'm taking them into Max and often then need to paint over the top of them in photoshop, the painting process often has to span multiple tiles. If i could export the DTM tiles (and therefore the images) at 1024m that would help me a lot.
I've had a flick through the install folder to see if there was an ini file which may have a setting but haven't had any luck.
Any ideas?
Neil
Hi @neilcooper33
I made this video for show how can you get the entire image from the FBX
Eduardo Soethe Cursino
Civil Eng. | BIM Specialist
Soethe Cursino Consultoria | BIM for Infrastructure | LinkedIn
Autodesk Certified BIM Specialist: Road and Highways Solution
AutoCAD Civil 3D Certified Professional
__________________________________________________________________________
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma reposta e Kudos de gostou.
I realize this thread is old, but I have the same question and the screencast has been deleted. Is there a current solution to this issue?
