Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
TRY STARTING - MAPGUIDE ENTERPRISE 2007 SITE SERVER NOT RUN
5 REPLIES 5
333 Views, 5 Replies
In panel service control the MapGuide not run.. see the picture please...
HELP I NEED MAPGUIDE ENTERPRISE RUN
5 REPLIES 5
Did you install mapguide in "registered" or "evaluation" mode?
It could be because mapguide could not find the licence server.
I think Dvergara (and me) have run out of the 60 day trial period.
How can I register Autodesk MapGuide Enterprise?
Where can I find the request/server code?
Thanks, Krisz.
Yes, the 60 day trial period has expired.
I installed the Network License Manager (NLM) which is on the install CD too. Then I registered the NLM (as an ADN member). Then I had to configure an NLM service (based on the license file). When I reinstalled MapGuide Server I had to specify the serial number and the host name of NLM. Since then MapGuide Server (service) is working / running.
Thanks, Krisz. 🙂
THANKS......................
Help!!!
I am having the same problem. I have set up the NLM and it is reading the license file and everything seems to be working but I can not get MapGuide Server to run. When I try and start the service I get
Could not start the MapGuide Server service on local Computer.
Error 1067: The process terminated unexpectedly
