Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
SQL SERVER SPATIAL COORDINATES FLIP
3 REPLIES 3
2845 Views, 3 Replies
currentlky i have several layers stored in MS SQL server 2008 if i query them inside sql server management studio, the layers appear normal, but one i try to load them into mapguide, the x and y values swap, creating a 90° map.
this would be a nice feature if you could enable with a click, but this is a bug, and a big one to start, this mean that i can´t really load data from a MS SQL Spatial.
is there a way to fix this? this also happens in map 3D.
this is the layer in MS SQL SERVER
this is mapguide
3 REPLIES 3
gluckett
workaround: store ll coordinates in geography rather than geometry
in reply to: gluckett
its a workaround but it works! thank you!
gluckett
This BUG has no HOTFIX and is STILL Broken with the FDO 3.7 for the following products:
  • MapGuide Open Source 2.4
  • Autodesk IMS 2013
  • AutoCAD Map 3D 2013
  • Autodesk Infrastructure Modeler 2013
Technology Administrators
