the 2015 release of AutoCAD map3d public on AIMS the DWG file instead of the DWF file
I need to know if is possible insert a new CAD block with the same code (below) that I used for data source spatial layer?
Dim commands As MgFeatureCommandCollection = New MgFeatureCommandCollection ()
commands.Add (New MgInsertFeatures (GetMarkupName (), propertyValues))
featureService.UpdateFeatures (featureSourceId, commands, False)
thank you for all your suggestions
andy
Hi Gordon,
Thank you for your answer
I also use a spatial db to insert, move and delete points
but this then requires a synchronizer to bring the information on the source dwg
I have developed a synchronizer but this needs to be updated for each client organization
regards
andrea
