Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Creating connection in Studio 2012 to SQL database
3 REPLIES 3
536 Views, 3 Replies
We are able to setup a connection to our database. Where the problem is, is the field selected in the primary table and the field from the SDF are the same, but when we go to view the data joined we see the fileds from the SDF and only the field names from the table. Thedata does not populate the jioned fields.
Any suggestions?
3 REPLIES 3
gluckett
i would make sure the column in the sdf is the exact type in sql sever, for example both INT
Thank you for the suggestion. Yes, we have made sure that this is the case for all fields.
gluckett
i would recommend storing the spatial data in SQL server rather than SDF, then you can join in a view
