This guide is for IT managers, CAD or BIM managers, technology administrators, or anyone charged with implementing Autodesk Informed Design.
As a technology administrator, you are crucial in ensuring your team can access and effectively utilize Informed Design.
This guide provides the information you need to understand the basics of Autodesk Informed Design, including how to download, install, license, and support it.
Click here to access the Autodesk Technology Managers portal.
Our products are designed to be trustworthy, so you can confidently design and make anything.
We strive to protect data, make our products available whenever and wherever you need them, and treat everyone with empathy and fairness.
Click this link to learn more about Autodesk's commitments to security, privacy, and risk.
Autodesk Informed Design is a platform-based solution that brings manufacturing information to the beginning of the design process to inform design decisions and improve project certainty, prevent errors, and accelerate our customers' workflows.
It allows subcontractors and manufacturers to define and share their construction products with architectural designers, including any allowable configuration.
This provides Revit users the ability to configure a construction product for their specific needs and know the results will meet the supplier or manufacturer's criteria.
To learn more about Informed Design, check out the Frequently Asked Questions (FAQ’s) page.
Autodesk Informed Design is currently available to Autodesk subscribers at no additional charge.
At the time of writing (March 2025), Flex tokens are not required to generate outputs from Informed Design.
Click here to find out more about Autodesk Flex
Click here for the Informed Design system requirements, including information on hardware, network, operating systems, and supported browsers.
To publish manufacturing content, the following is required:
To configure and place published content, the following is required:
To generate outputs, the following is required:
*Autodesk Revit 2024, Inventor 2024, and later versions are supported by Informed Design.
†Informed Design supports the publishing of content to the Autodesk Docs US server only (as of March 2025).
(See ‘Autodesk docs cloud permissions’ below for more information).
Informed Design’s integration with Autodesk Construction Cloud (ACC) Bridge allows manufacturers to publish products to their own project folders and seamlessly share these folders with other accounts and projects across the Autodesk Construction Cloud.
An Autodesk Docs license is required to publish products to ACC and share them using Bridge.
At the time of writing, ACC Bridge functionality does not support cross-region data transfers between Autodesk Construction Cloud (ACC) data centers in the US, EU, and APAC regions. ACC Bridge only allows folders and files to be shared within the same regional data center.
Click here to learn how to use Informed Design and ACC Bridge.
Autodesk Inventor, and Autodesk Revit are available for a 30-day trial at no cost.
Click here for Autodesk Software free trials.
The Autodesk Docs trial is accessed separately.
You can sign up for an Autodesk Docs trial by clicking on this link.
To access the Informed Design web app, visit https://informeddesign.autodesk.com/
To download the informed design for Inventor and Revit, click on the question mark ‘?’ symbol and follow the instructions.
You can find additional information in the Informed Design Installation guide.
The Informed Design add-ins will prompt when they need updating. To update the Informed Design add-ins for Revit and Inventor, follow the instructions in the Access & Installation guide.
Users will need an Autodesk account to be allocated a license.
An active license of Inventor 2024 or later is required to publish manufacturing models to Informed Design.
An active license of Revit 2024 or later is required to discover, configure, and place content from Informed Design.
A Revit model must be published to Autodesk Docs to generate manufacturing outputs, this requires an active license of Autodesk Docs.
Manufacturing outputs can be saved to any of:
A corresponding license allocation and permissions are required to publish to these locations.
Revit and Autodesk docs are included in the Autodesk Architecture, Engineering & Construction Collection
Inventor and Fusion Team are included in the Autodesk Product Design and Manufacturing Collection.
Click this link to determine which Autodesk subscription plans work for your company.
Informed Design utilizes Autodesk Docs and folder permissions to manage access when using Informed Design for Inventor and Revit.
The Autodesk Informed Design API is now available in public beta on Autodesk Platform Services (APS), unlocking new capabilities for developers to integrate, automate, and extend design-to-manufacturing workflows in the cloud.
We’d love to hear how you’re using the API during this public beta. Your feedback is critical to shaping the future of Informed Design.
Give feedback:
Join the Autodesk Informed Design Forum
Submit ideas on our IdeaStation
Users can learn how to use Informed Design by visiting 'Get started with Informed Design’ on Autodesk Learn.
They can also visit our Help pages for feature-level guidance.
The Autodesk Informed Design blog, for workflow articles, what’s new, and our product roadmap.
Sign up to the Informed Design newsletter to keep up to date with the latest articles.
Visit Autodesk University Online ‘AU’ for year-round self-paced learning content by Autodesk and our expert customers.
Deep dive into the following topics in an hour or less:
Peer support for you and your users is available via the Autodesk Informed Design community forum.
Click here to raise a support ticket with Autodesk directly or send this link to your users with instructions on how to raise a technical support case with Autodes...
Additional technical support is available depending on your subscription plan. Click here to learn about the levels of Autodesk technical support.
Click here for learning material for Autodesk Account managers. Learn how to add and remove users, assign product access, and manage teams, groups, and guests.
If you are new to administering Autodesk software' visit the Autodesk Account Quick start guide for comprehensive learning material. Understand your role as an administrator, get up and running with your new Autodesk subscriptions, and learn how to download, install, and activate Autodesk software.
You can also check out our Technology Admins events page for webinars relating to topics such as Single sign-on, desktop product updates, and cloud migration.
You can find support from Autodesk and your peers in the Autodesk Technology managers community. Please click here to join the Autodesk Tech Admin Community.
Click here for the Autodesk Tech Admin Roadmap, and discover the projects we are working on to help you save time and increase efficiency.
Click here to sign up to ‘The Quarterly Byte’, the Autodesk Technology Admin newsletter.
