Informed Design: Is there a failure log, which can be accessed when a variant fails to generate?
JMGunner
Message 1 of 18
JMGunner
Is there any options too access "Open Failure log"
then you try too "Insert" model
Picture 1
in OutPut you have the options too see log
Picture 2
Best JM Gunnar
Replies (17)
Message 2 of 18
PaulMunford
Hi @JMGunner That is a great question - thank you! In this case, I don't know the answer. Let me find out for you.
Paul
Paul Munford
Technical Onboarding Architect
Linkedin
Message 3 of 18
PaulMunford
Hi @JMGunner Thank you for your question. The short answer is 'No', we currently do not offer an option to access the log for failed variants.
Perhaps you could give us more details on the problem you are facing, and perhaps we can help you find a solution?
Thanks very much.
Paul Munford
Linkedin
Message 4 of 18
JMGunner
I can send you 2 exampel too you @PaulMunford
Message 5 of 18
PaulMunford
@JMGunner Great 🙂 Please feel free to DM me links. Please include whatever context you can about the failures. This could be written, screen captures, or a video screen recording. Whatever works for you. Thank you!
Paul Munford
Linkedin
Message 6 of 18
JMGunner
Debug rule in Informed Design
Check this fail logger for creating drawing
Automation Works all the process to end
I add the Trace logger in "APS"
iLogicVb.Automation.LogControl.Level = LogLevel.TraceLogger.Trace("Start Dimension")
Logger.Trace("End Dimension")
if the ilogic rule "crash"
I can se this in the logger
if I only find the first Logger.Trace("Start")
then i know which rule thats not working.
The process crash in the end
[05/06/2025 14:02:12] InventorCoreConsole.exe Error: 0 : Exception thrown from RunWithArguments
this is the hard error too find soultion.
Best Regards JM
Message 7 of 18
PaulMunford
Thanks @JMGunner, am I correct - is this the debug log from an iLogic rule that is running on your local machine?
Or - is this an example of what you'd like to receive when a variant fails to generate?
Thank you.
Paul Munford
Linkedin
Message 8 of 18
JMGunner
@PaulMunford
this is debug log from Informed Design  "balcony"  then i try too create one PDF
1.
How I debug ilogic rule in Informed Design
I add this too iLogic code
2.
In all ilogic-rule I add Trace in start and end of the rule
Logger.Trace("Start" name of ilogic rule)
Logger.Trace("End" name of ilogic rule)
3.
If I get error in the rule
It only Trace "Start"
4.
If i read the logger file I see thats all my iLogic works.
5.
I can not find where Error Inventor Error  in PDF generation
Last row
Best Regards JM Gunnar
Message 9 of 18
PaulMunford
It looks like the iLogic script creates a PDF and a zip file and writes them to a local drive?
If so, this would not be supported by Informed Design. Informed Design packages your configurable Inventor model and uploads it to Autodesk Platform Services, where the 'headless' version of Inventor is used to apply configurations to the model. After configuration, the files are deleted. The next time a configuration is requested, the original configurable model is loaded again.
Is that helpful?
Paul Munford
Linkedin
Message 10 of 18
JMGunner
"local drive is Autodesk Platforms Server "
1.Informed Design send the zip-package too Autodesk Platforms Service
2.It's zip the folder then run all ilogic rule  / save "PDF/DWG/Asssembly"
3.Zip the result
4.Send back result too Output
It's not my iLogic rule
Message 11 of 18
PaulMunford
Thanks@JMGunner. I apologise that this is taking me a little longer than usual to resolve. I have escalated it to the product team. I will get back to you on Monday with an update.
Have a great weekend.
Paul Munford
Linkedin
Message 12 of 18
JMGunner
I  zip  and send the demo test too you
on monday
if you want
Best Regards JM
Message 13 of 18
PaulMunford
Thanks @JMGunner I have passed on your dataset to our product team. I'll report back on the results.
Paul Munford
Linkedin
Message 14 of 18
PaulMunford
@JMGunner  Just to let you know, I'm still chasing an answer for you.
Paul Munford
Linkedin
Message 15 of 18
PaulMunford
Hi @JMGunner We think that the iLogc rule that is trying to write out a PDF and ZIP may be causing the problem. Can you try suppressing this rule and publishing again?
Let us know if that works?
Paul Munford
Linkedin
Message 16 of 18
JMGunner
i try too send by its limits number messesge ...   🤔
Message 17 of 18
deepikag2
Hi @JMGunner, sorry that you're running into issues and thanks for all the debugging you did! Our product team took a look into this issue. It looks custom dlls are being used as part of the dataset and they are loaded as part of iLogic script execution. The use of external dlls isn't supported by our Design Automation processing and is the likely cause of the error you are observing.
Message 18 of 18
JMGunner
I use this dll with APS Design Automation Inventor
@deepikag2
Is there any options too Catch more info from error in logg file ?
[05/31/2025 22:26:11] InventorCoreConsole.exe Error: 0 : iLogic error
[05/31/2025 22:26:11] Details: System.FormatException: Rule Compile Errors in PlaceViews, in BalconyDLL.dwg
for info in future
Solution
iLogicVb is support by
Create iLogicVb for Informed  Design Automation processing
ilogicUtils.iLogicVb
Best JM Gunnar
