Cannot Publish product definition for Informed Design - Could not load file 'ForgeUnitsCLR ...
Michiel.Valcke
Advisor Advisor
Michiel.Valcke
I have been working with a demo set from Autodesk (ID_Roof Screen) to try and get the Informed design workflow working and see how it all runs before throwing our own designs at it, but I'm still running against a bunch of things. The latest of which is the following issue:
'Could not load file or assembly 'ForgeUnitsCLR, version=4.0.3.0, Culture=neutral, PublickKeyToken=null' The system cannot find the file specified.'
I have scoured the internet where I could find the necessary dependable but so far I have no luck. I'm assuming there is some type of Forge component that needs to be installed. Does anyone know how or where I can get the necessary component?
raj.inugala
Hello Michiel,
Are you on Inventor 2025? If so, can you please uninstall and reinstall the latest Informed Design addin? This should ideally fix your issue.
Thanks!
Michiel.Valcke
That fixed that issue. Thank you very much.
