Cannot Install Informed Design with RVT 2024.2
umut.akparlar
Message 1 of 8
umut.akparlar
I have the latest Revit version but still cannot install or use Informed Design for Revit. I have revit 2024.2 open in the background and checked Autodesk Access for updates but on the same screen Informed Design Installer states Revit 2024 is required.
Replies (7)
Message 2 of 8
gareth_spencer_adsk
Hi @umut.akparlar,
Are you trying to install the add-in whilst Revit is open? If so please closed down Revit and try again.
Please let me know how you get on.
Gareth
Gareth Spencer
Customer Adoption Specialist (Autodesk Informed Design Team)
Message 3 of 8
umut.akparlar
First I tried it with Revit closed then I opened it to show I have latest version of revit.
Not working for both scenarios.
Message 4 of 8
gareth_spencer_adsk
I am sorry to hear that @umut.akparlar.
Did you download the add-in from your Autodesk account or via the product page?
If you didn't get via the product page. Can I ask if you can try and download it from there. Please follow these instructions here where to go.
Oh does the add-in file you downloaded have the build number in the description? It should say something like 1.0.0.0.
Gareth Spencer
Message 5 of 8
umut.akparlar
I was using following website:
https://informeddesign.autodesk.com/revit
Downloaded filename is " Informed Design Add-In 1.0.0.0 for Revit 2024.msi "
Message 6 of 8
gareth_spencer_adsk
Hi @umut.akparlar,
When installing it checks the registry to determine if Revit 2024 is installed. Can you please run regedit an go the location Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Revit\2024\REVIT-05. It should show the same as in the image below.
What do if display on your machine?
Gareth Spencer
Message 7 of 8
gareth_spencer_adsk
Hi @umut.akparlar,
I just wanted to follow up on if you managed to install the Informed Design add-in ok?
Gareth Spencer
Message 8 of 8
umut.akparlar
Thank you for the support but I did not have proposed registry keys. I will try installation with another machine.
