BIM Definition for Inventor 'null' error
lorrinbCD66K
Message 1 of 10
lorrinbCD66K
I am getting this error when I load the BIM Definition for Inventor via Add-Ins.  If I unload this add-in the error goes away.   Any would be appreciated.
Accepted solutions (4)
Replies (9)
Message 2 of 10
deepikag1
Hi @lorrinbCD66K, could you please provide us with some more information on the error you are seeing?
  1. Does the error occur when starting Inventor or only after a document has been opened?
  2. Can the error be reproduced if Inventor is first started with the BIM Definition add-in deactivated and the BIM Definition add-in is then manually activated?
  3. Have any 3rd-party add-ins been installed and if so, which ones?
Message 3 of 10
lorrinbCD66K
1. Error occurs at start up.
2. Error can be reproduced if BIM Definition is deactivated and BIM add-in manually.
3.  3rd party:  Informed Design
Do AutoDESK Docs have to be installed for the BIM Properties panel to show on the ribbon.
Message 4 of 10
lorrinbCD66K
Not sure if this is the exact fix, but I used the Inventor Reset Utility and the error went away.  The  BIM Definition tab now appears on the ribbon.
Message 5 of 10
deepikag1
@lorrinbCD66K Thanks for the information! Did you happen to have the 'Amber' setting checked in the 'Application Options ' Colors tab? We think the issue might be related to having the 'Amber' setting checked in the Light UI Theme. Unchecking that seems to be a workaround for this. Using the Inventor Reset Utility will probably default to Light theme with the 'Amber' setting unchecked which is why it fixed the issue for you.
Message 6 of 10
lorrinbCD66K
Did not have Amber setting checked.
Message 7 of 10
deepikag1
Thanks for checking. We will continue looking into this issue but we can use the Inventor Reset Utility as a workaround until then.
Message 8 of 10
lorrinbCD66K
FYI, I did go back and check the 'Amber' setting.  This caused the error to occur again.  I then unchecked the 'Amber' setting and the error went away.  So there is definitely an issue having the 'Amber' setting is checked and trying to load the BIM Definition Add-In.
Message 9 of 10
PaulMunford
Hi, @lorrinbCD66K, Thanks very much for bringing this to our attention! If you feel that the issue has been resolved, please could you use the 'Accept solution' button? Thank you! ~Paul
Customer Adoption Specialist: Autodesk Informed Design
Help | Learn | Forum | Blog | Ideas | Sample content | Linkedin
Message 10 of 10
PaulMunford
@lorrinbCD66K Thank you for accepting a solution! 🙏
