해외 블로그에서 퍼와서 활용했던 기능입니다.
위의 새로워진 기능과 유사한 ilogic 기능~
퍼 온 링크는 기억이 안 나네요~
파일도 첨부합니다~
Sub Main()
Dim oDoc As PartDocument = TryCast(ThisDoc.Document, PartDocument)
If oDoc Is Nothing Then
MessageBox.Show("This rule works with part documents only.", "iLogic Rule", _
MessageBoxButtons.OK, MessageBoxIcon.Warning)
Exit Sub
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
'this rule works with only one rect. pattern only
'provided directly by item number
Dim oPattern As RectangularPatternFeature _
= oDef.Features.RectangularPatternFeatures.Item(1)
'restore all pattern elements in order to get access to their faces
For Each oElt As FeaturePatternElement In oPattern.PatternElements
If oElt.Suppressed Then oElt.Suppressed = False
Next
oDoc.Update()
ThisApplication.ActiveView.Update
Beep
Dim oBoundarySketch As PlanarSketch = oDef.Sketches.Item("스케치3")
'temporary sketch for profile
Dim oSketch As PlanarSketch = oDef.Sketches.Add(oBoundarySketch.PlanarEntity,False)
oSketch.Visible = False
'project boundary
For Each oE As SketchEntity In oBoundarySketch.SketchEntities
Call oSketch.AddByProjectingEntity(oE)
Next
'project parent hole
Dim oHole As HoleFeature = TryCast(oPattern.ParentFeatures.Item(1), HoleFeature)
If oHole Is Nothing Then
MessageBox.Show("This rule works with hole feature pattern only.", "iLogic Rule", _
Exit Sub
Dim oEdge As Edge = oHole.SideFaces.Item(1).Edges.Item(1)
Call oSketch.AddByProjectingEntity(oEdge)
'project holes pattern
If oElt.Faces.Count > 0 Then
oEdge = oElt.Faces.Item(1).Edges.Item(1)
Next
' Create a profile.
Dim oProfile As Profile = oSketch.Profiles.AddForSolid(True)
For Each oPath As ProfilePath In oProfile
If oPath.Count = 1 Then
Dim oPE As ProfileEntity = oPath.Item(1)
If oPE.CurveType = Curve2dTypeEnum.kCircleCurve2d Then
Dim oSkE As SketchEntity = oPE.SketchEntity
Dim oGreenCircle As SketchCircle = CType(oSkE, SketchCircle)
Dim oFPE As FeaturePatternElement = GetEltByGreenCircle(oGreenCircle)
If oFPE IsNot Nothing Then
If oPath.AddsMaterial = True Then
oFPE.Suppressed = True 'should be suppressed
Next
'delete temporary sketch
oSketch.Delete()
oDoc.Update()
Beep()
End Sub
Function GetEltByGreenCircle( _
ByRef oGreenCircle As SketchCircle) As FeaturePatternElement
'returns FPE corresponding to the given SketchCircle object
If oGreenCircle Is Nothing Then Return Nothing
Dim oEdge As Edge
Try
oEdge = CType(oGreenCircle.ReferencedEntity, Edges).Item(1)
Catch ex As Exception
Return Nothing
End Try
Dim oFace As Face
If oEdge.Faces.Item(1).SurfaceType = SurfaceTypeEnum.kCylinderSurface Then
oFace = oEdge.Faces.Item(1)
Else
oFace = oEdge.Faces.Item(2)
If oFace.CreatedByFeature.Type = ObjectTypeEnum.kHoleFeatureObject Then
Return Nothing
Dim lKey As Long = oFace.TransientKey
= CType(oFace.CreatedByFeature, RectangularPatternFeature)
If lKey = oElt.Faces.Item(1).TransientKey Then
Return oElt
Next
Return Nothing
End Function 'GetEltByGreenCircle
줌인테크 Techanical Support Engineer
