Tangent Joint
Tangent Joint
I do a fair amount of work with cams, slot-sliders, and other contacting surfaces. It'd be really nice to have some sort of tangent joint to fix two surfaces tangent to one another regardless of their orientation. This would be really usefull for designing cam systems and more complicated slot mechanisms that can't be captured by the pin-slot joint.
7 Comments
HughesTooling
Take a look at this thread and the screencast in post #16. This is not a solution, we still need a tangent joint but it might help.
Mark
tjstephens
Will contact sets do some of this for you?
promm
Thank you for your idea, this is getting changed to future consideration.  The problem that we are going to solve is having a tangent relationship between components.  We are exploring options that include contact sets, constraints and joints.  Once work is started this will be changed to future consideration.
Mike Prom
Internal Tracking FUS-26127
Murdug
Thanks Mike. I fully agree, a tangent constraint/joint between components will be great! (with the option to off-set). The workaround is really tedious for something that could be a click of a button. Like Keqingsong said 13 July, "Now you just have to click once, because you should never have to click more than you really need to". 🙂
I'm also in need of a tangent constraint. I think the work around is just too much... well... work. I have to carefully construct the joint origins, and then will have to create basically a virtual component to be the planar joint to allow the sliding I need.
How has this still not been implemented?
michael_woodrum
I just spent a few hours attempting to get the motion that I need. Then I thought I would search. This is needed for sure. Please consider adding this. I would love to have the ability to easily do this as well as simulate it before making it for real.
