New Option for the Setup Sheet
I think the Setup Sheet is very useful, and everyone that sees it agrees. Currently the Setup sheet shows each tool, feeds, Speeds, etc - which is great. What would be great is to also show the starting line number of code for each operation. I don't know if this is already in there. it would be very helpful for those that make minor tweaks to the program using the machine editor. Having the line number would make it way to jump the number quickly instead of having to scroll through every line to find the operation.
I don't know if that is not included becuase maybe the post processing hasn't been created yet, but maybe having an approximate line number is better than not having that information at all.
Thanks again. Fusion is great!
Dave
2 Comments
This would only be possible if the set-up sheet was made or called from within the post processor.
So this is possible, you can have a look here on how to get your self such a post processor and set-up sheet: https://camforum.autodesk.com/index.php?topic=6138.0
Laurens, thanks for the reply. If the search was done via code line, I thought it may have something to do with the post-processing. As an option, what about inserting a unique value or phrase to search that new operation by - ie. Op1, Op2, Op3...
