So far I am able to rotate current view 90 degree clock or counter clockwise using the cube in the right upper corner. This works only if the the specific plane match standard view. When I use "LOOK AT" and select any face I want to work on in CAM or CAD environment, it is not viewed always as I want it or how I feel is easier for me to work on.
It would be nice to add maybe option, maybe icon or shortcut to be able to rotate current view 90 deg or any desired rotation (index), 90 deg or 30 or 1 deg .. or rotate to align selected edge or geometry to horizontal or vertical line..
I have attached below few screenshots to show what is on my mind.
Thank you
Marek
