Warning: Selected face not in job model selection!
I get this message when trying generate toolpath for thread milling.
Couple months ago it works. When i duplicate old operation (which works) and generate toolpatch it disapper and give me the same message in log.
Solved by mcgyvr. Go to Solution.
@Anonymous
Those questions are best asked in the HSM (Inventor CAM) support forums located here..
https://forums.autodesk.com/t5/hsm-support-forum/bd-p/216
I will ask a moderator to move this thread over there for you..
Hi @Anonymous,
Is your dataset one or more Bodies/components?
If so, it looks like that body/component isn’t selected within the setup.
Can you share your data so one of us can take a look at it?
If my post answers your question Please use .Accept as Solution & Kudos This helps everyone find answers more quickly!
