TUTORIAL: edit expressions
Message 1 of 10
is there some kind of tutorial for learing to edit the expression in HSM?
i want to change the dwell time to: 90000/tool spindle speed, but i dont get it working
Replies (9)
Message 2 of 10
FTKnur
Hi @Anonymous,
just hover with Shift+Mouse over the Value that you want.
Then you get the Parametername. In this case it is tool_spindleSpeed (upper cases!)
This is possible with many options (checkboxes, heights ... but not the Clicked Diameter in bore operations - too bad 😕 )
900000 / tool_spindleSpeed
Message 3 of 10
thank you fir your reply!
Do you know if its also possible to round down the results?
i become a value of 0,040395 s but i would like a value of 0,040
Message 4 of 10
or is it possible to make an expression like this?
if tooldiameter = 4 then dwell = 0,016
if tooldiameter = 10 then dwell = 0,040
Message 5 of 10
denis_q
In HSMWorks the ternary operator should do the trick:
Syntax
result = binaryCondition ? valueReturnedIfTrue : valueReturnedIfFalse
e.g.: tool_diameter==4 ? 0.016 : tool_diameter==10 ? 0.04 : ___
Where '___' is the returned value if none of the conditions are true.
Message 6 of 10
denis_q
In HSMWorks it's possible to use (some) javascript??? functions.
e.g. Math.round(0,040395*100)/100
Message 7 of 10
FTKnur
@Anonymous
The easiest way for your dwell time is "tool_diameter * 0,4" ... with the function from @denis_q it is  also possible but you realy have a lot to write? Don't know what you exactly want 🙂
Message 8 of 10
And selecting the holediameter for making an expression like 0,7* holediameter isn't possible?
Message 9 of 10
FTKnur
Nope ... the diameter of your selected hole/surface is not possible.
Only thing is makeable with "diameter range" ... don't know if you can use it.
I have a templates for different threads -> e.g.  M6 -> both diameter ranges set to: 4,917...
Automatic boring for standard operations 🙂
Message 10 of 10
ArjanDijk
I don't think you will find anything better then this video:
Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
