HSM Support Forum
Smoothing Toolpath passes
3 REPLIES 3
pg471939HMBM
230 Views, 3 Replies
In the toolpath shown in the image, the tool begins machining through a spiral movement. From a certain point onward, the tool machines only in circles, with abrupt transitions to the next circle. Is it possible to smooth the toolpath between passes or to continue the spiral movement?
Thanks in advance.
Francisco Silva.
3 REPLIES 3
Hi
The final geometry of the path is influenced by many factors - strategy, transition settings, finishing, stock, etc.
Without the attached file, it's hard to comment.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Thanks for the answer. The file is attached.
Select "Use morphed spiral machining" in Passes tab.
Kacper Suchomski
