Restoring Drill Operation Default
roger
roger
Recently, while in the CAM operation tree, I right clicked on a drill operation an inadvertently hit the "Make Default" option. Now, all of my drill operations use the settings in place at the time for that particular drill operation. The "Cycle Type" no longer uses information from the tool type to preselect the cycle. In other words, when I used a tap, the Cycle Type would already be selected as "Tapping" or when I used a ream the Cycle Type would be preselected as "Reaming - feed out". Now, all tools use the settings in place at the time I hit "Make Default".  How do I restore the drill operation defaults so that it once again recognizes the tool type?
Roger
ianty85
delete a "drill" from windows registry in Computer\HKEY_CURRENT_USER\SOFTWARE\HSMWorks\HSMWorks\defaults
roger
I couldn't really follow that path reference. I don't see anything similar on my computer. I take it there is not a process within the open Inventor application?
jeff.pek
To get to that area, you need to open the Registry Editor (RegEdit) app. It will look something like this:
Jeff
