OPtimal Strategy for machining round undercuts
- Mute
- Permalink
- Report
Hi All,
My first post!
Ok two areas I am struggling with and hope the community may have some ideas on best practice etc.
Number1:
You'll see below I need to figure out a way on my 3axis CNC mill to machine the undercut, i.e. the inside edge and associsted surface. I have to date been using "3D Contour". Possibly doing something wrong, but I would expect I'd be able to select the inside surfaces to machine and it would generate accordingly, but appears to need a contour to follow. Is it not possible to simply select surfaces for it to machine?
Number 2:
You'll see below the part I am trying to machine. At the moment I need to machine one side, then flip over re-zero then machine, then flip onto side re-zero then machine, etc. Interested in any ideas on minmising the amount of re-zero etc to speed up time to manufacture. Note, I only have 3 axis machine.
Thanks guys, hopefully some ideas.
