Can't find the "NC Assistant" in the 2018 HSM? Editor version 8.01.05
Solved by Steinwerks. Go to Solution.
Solved by ivan.stanojevic. Go to Solution.
Ivan Stanojevic
The skinned version of Cimco has never been supplied with Fusion 360, this has nothing to do with Fusion at all.
You need licensing rights for previous versions of HSMWorks or Inventor HSM though, but that's it (IE you had the editor before so you qualify).
OK thanks. I am just trying to figure out how to get the download link for the zip file in the video.
Expand the description of the video and there are two links for Dropbox downloads, one for the HSMWorks editor and another for the Inventor HSM editor.
It shouldn't be missing but I'm not using that download.
@scottmoyse That's in your download correct?
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
I believe he's referring to the Macro Setup button/dialogue on the NC Functions tab.
Scott Moyse
“Autodesk just responded and stated that 2018 now ships with Cimco Standard.
This results in a LOSS of functionality. (Backplot and NC Assistant) These only comes with the higher level of the Cimco Editor.
The customer only has two options… 1) Revert back to 2017 or 2) Purchase the higher level editor from Cimco.”
Wow! I use these features daily, this really sucks!
