- Mute
- Permalink
- Report
I've got a Haas TRT160 (tilting rotary table) on a Haas DM-2. The A frame & rotary table are mated appropriately within the TRT160 subassembly and rotate perfectly within the subassembly. I've set the machine file up to where I believe it is perfect, including axis order. I've pre-set the machine table so that the intersection of the rotary axes is directly below the spindle.
When I try "manual control", the X/Y/Z axes work as expected. But both the A & C axes, while rotating in the correct orientation, rotate about some arbitrary point instead of their center-axis (which is how they rotate within the subassembly). I have tried everything; offsets within the machine setup have no effect, I've tried creating a whole new assembly with both the machine & the TRT160 as separate subassemblies, nothing seems to fix it.
Here is the link to the assembly file (all parts are virtual within the assembly), and here is the link to the machine setup file along with a screenshot showing the setup-order and then the incorrect rotation. I'll post some screenshots of the setup in a reply post. Running HSMWorks 2020 R0.43580 with Solidworks 2018 SP3.
Incorrect Rotation
Machine Config
