Machine a radius at intersecting hole? (cross hole deburring)
LibertyMachine
Mentor Mentor
LibertyMachine
I'm struggling to come up with a toolpath for this feature:
This is a part I've been doing for many years now, and the feature in question has (up until now) been done with an Orbitool and then hand blended in with small 3M bristle disks.. There has never been enough need to program that feature, due to part quantity and machine ability (old Matsuura). Well, that has changed a bit (new Kitamura and large qty of parts) and I'd really like to remove as much "hand work" as possible. The feature in question is a 1mm radius, but truthfully, it just needs to be a smooth transition so wires don't suffer abrasion. I've tried Ramp, Scallop, Morph Spiral, all to no real success. A search indicates that "Blend" is going to be the answer, but it's failing on me, so I'm not sure what I'm doing wrong.  (Fusion Blend is broken, according to my sources)
Looking for suggestions or ideas, part is attached
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Steinwerks
Yeah, Blend is looking pretty good Smiley LOL
I would really like to see stock comparison in F360 too (what's seen above). This was with no collisions. I'll see if I can get something nicer in Fusion though.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Steinwerks
Figured I'd see if I could hack in Blend and... this is depressing:
Neal Stein
Find me on:
LibertyMachine
Yup, what I got as well
Seth Madore
Steinwerks
I tried to shoehorn in a Blend operation as a template but since you can't edit the geometry without getting that error, no dice.
Neal Stein
Find me on:
Dear friend,
To see if i can help you i need the 3d file (Step of igs, whathever)
If you still interested on a usefull hand from Portugal get back to me on     vitor.s.marques.1974@gmail.com   owner of HM - Maquinação See it on www.hmmaquinacao.com.pt
Waiting your reply
Vitor
Greg_Haisley
@LibertyMachine I got to ask. Is the edge fillet because you don't want to cut an o-ring with a mating part?
